Thanks. Has anyone tried cable swapping on the newer batch?
I have. No issues.
I wouldn't bother getting comply. I have had TX-400s with previous earphones and they lasted no longer than my generic memory foam tips.
3X Comply TX-400 = £19.99 RRP
6X Generic with plastic storage box = £5.99
Will FiiO itself sell any the spare parts for F9-series? Like ear tips, cables and etc.Hi,
Checked again just now. Both 400 and 500-series could be compatible. The core inner diameter of the f9 is 5.0mm.
Best regards
Could you share some links of the generic tips that you have tried yourself. Thanks!
I have. No issues.
These Ostry tips looks really awesome ,If you're not in a hurry, you can buy them at AliExpress
https://es.aliexpress.com/store/pro...792.html?spm=2114.12010608.0.0.2f94e5d4kepl2w
I also use the Ostry OS200
https://es.aliexpress.com/item/OSTR...6A-KC06-KC08-KC08T-and-other/32811986724.html
I guess this cable looks similar to this one available here:Are these Balanced cables? do you happen to have direct link to buy, please.
Thank you
Nice. I should have recieved mine today but dhl forgot to hand it over to the domestic courier and now its gonna take a extra two days.Just received the F9 Pro. 3 days shipping from Hong Kong to Malaysia. Comes very well packed with outer box and bubble wrap plus styrofoam. Will post more unboxing pics later.
