ivantoar
- Nov 2, 2011
Hi guys,
Last time I posted here to get a recommendation on headphone. So I decided on Superlux HD668B and I was quite satisfied with it. But then, I thought to go further and I bought a Fiio E9 yesterday.
After a few listen, I noticed that my Fiio E9 makes my music sounds worse. I noticed this when I was listening to Rock music. With the Fiio E9, there are some details in the music missing and the drums sounds so flat whereas I got punchy drums if I don't use my amp.
I don't have Fiio E7, so I use 3.5mm to 3.5mm to use my Fiio E9. One side is plugged to speaker/headphone jack and the other is plugged in to Fiio E9's line in jack. Then I plugged in my Superlux HD668B which is using 3.5mm plug to the headphone output jack.
My Fiio E9 volume is set to 10 o' clock degree and gain is switched to high.
So, what is wrong with this? I expected a sound quality improvement. Is my E9 defective? Is there any wrong installation procedure? Is my headphone is not good enough to be amped? Or is it simply because my ears are crap?
Thanks in advance
Thanks in advance
