Raymate
- Feb 28, 2004
Using the E7 with the stock USB, is anyone using a high quality USB cable and do you notice any difference.
And good cable you can recommend?
I o not want to spend a fortune on one.
Has anyone found a good one from deal extreme , I actually use them to get my Fiio products but it's hard to find stuff on the site like specific cables etc.
Cheers
Cheers
