ouchmyears
- Jul 24, 2013
I am loking for a portable amp and I was wondering if the fiio e17 would work good with a samsung galaxy s4 active?
Will I be using it the fiio e17 to its full potential with the phone or is it more designed for use with a ipod or I phone?
If it will work what all accessories would you recommend for it. What all would I need to get the best out of it?
If the e17 will not work what would you recommend.
Thanks for reading Brad
Sent from my GT-P3113 using Tapatalk 4
