Fiio e11[ISSUES!!!][PLEASE HELP!]
Apr 22, 2012 at 7:11 PM Thread Starter Post #1 of 8
delladood
I just unplugged my headphones from my fiio e11, assuming it died, I went ahead and plugged it into my usb... Well... It's not charging. No light is coming on indicating it is charging.  This is the second day I've used. Did it just die
?? Or is it completely dead.  I'm going to leave it on the charger for awhile. any thoughts?
Apr 22, 2012 at 8:15 PM Post #2 of 8
It's holding a charge. But the little orange light that should appear indicating that it is charging is not working at all... But it is holding a charge. has anyone experienced this?
Apr 22, 2012 at 9:02 PM Post #3 of 8
Take the battery out and put it back in. Then try to charge it. Often when E11 goes fully flat you must do this or it appears dead.
Apr 22, 2012 at 9:22 PM Post #6 of 8
Apr 22, 2012 at 9:35 PM Post #8 of 8
 I was thinking that before. For me I'd probably send it back, You need to know when a charge is full.
I might just get a refund.... and buy the e7 or e17. im also going to drain the battery again.
