Andrew_WOT
- Jan 18, 2004
Even ES100MK2 was better than LG G7 DAC. And BTR7 is a clear step up from that one.
Don't know about the ES100MK2 but BTR5 sounded hazy compared to G8x. Detail, stage... etc. was about equal but that haze/grainy quality up top was a turn off for me.Even ES100MK2 was better than LG G7 DAC. And BTR7 is a clear step up from that one.
BT or USB, if USB was it with bit perfect UAPP or Android resampling driver.Don't know about the ES100MK2 but BTR5 sounded hazy compared to G8x. Detail, stage... etc. was about equal but that haze/grainy quality up top was a turn off for me.
Not a fan of G7's sound, it leans towards a thin and cold sound signature. G8x is more neutral and a bit fuller sounding in comparison.BT or USB, if USB was it with bit perfect UAPP or Android resampling driver.
But I haven't heard G8x, only owned G7.
If I recall correctly, all of the BT dongles I have support only audio input on the USBC port. I don’t own the BTR7, but I doubt it will be any different.Hi,
I had a question about the BTR7 i don't think this has been asked and was wondering if anyone might know the answer to this?
Would it be possible to connect USB C headphones so using the USB C as an audio out?
I tried this with some Audeze Mobius headphone with a USB C connection and I couldn't get it to work. The Audeze Mobius also has a 3.5 connection so isn't an issue with these but potentially there are some headphone I might purchase in the future that only has USB C and no 3.5 connection.
I've seen some cables that are USB C to 3.5 but seem to work USB C to 3.5 and I want 3.5 to USB C that might be a work around if you can't have the BTR7 straight to a USB headphone connection.
Thanks all
No doubt that is the case for you. Do you have a BTR7? I think it would be useful to hear from BTR7 owners. Do they see this solely as a desktop replacement?I firmly believe that the BTR7's best case use scenario is not paired with a phone because of it's size, just too big to be practical to carry with you all the time. I look at the BTR7 as a travel alternative for a desktop dac/amp that stays in the hotel paired with a laptop.
Consider getting a BTR1 as backup to the backup to the backup and you'll never have to stop playing musicto me, the BTR7 is very pocket friendly. Used it throughout the weekend while doing yard work, replace it with the BTR5 when the battery needs charging ( a lot of yard work this weekend). BTR3 is the backup to the backup but rarely, if ever, need to use it
I have 5 other devices for backupsConsider getting a BTR1 as backup to the backup to the backup and you'll never have to stop playing music
One a serious note, how's the range on BTR7? does it get disconnected when your body gets inbetween the phone and BTR7?
Audeze Mobius is headphone with DAC and BT receiver. Why do you need BTR7 when you can connect it directly to the phone either via Bluetooth or USB?Hi,
Thanks all
Did you mean this link?Probably, I remember seeing a post somewhere detailing DAC chip used and who tuned the different LG Phones, one thing to keep in mind is that with warm sounding gear {Meze 99C, A&K Diana, Honeydew), there were times I liked the pairing with G7 but G8x sounded better with everything else. The differences isn't huge though.
