BenF
- Jan 22, 2013
I use sensitive headphones, so I'm usually at 18-22 BTR3K volume at the 3.5mm output (when phone volume is at 100%).may I ask what number you usually use on BTR3K? how much out of 32?
I suspect I'm using more volume that most people that's why I'm getting subpar battery life ..
It gives me an option to raise a volume on both BTR3K and the phone when needed - whichever one is more convenient at the moment.also is there a reason you don't use 100% on phone? I've read an article which said when you use software to lower volume you effectively lose bit depth and it's better to set software at full and tweak it with hardware
Bit depth loss is not something that has much effect compared to Bluetooth-related quality depreciation.
