You can disable the charging function from the onboard menu
If you forget to re-enable charging and drain the battery to the bottom, you'll want to plug in the BTR5 for a couple of minutes before trying to boot it back up - it can appear "dead", but it's just got an empty battery and not enough "umph" in it to power on -- then change that option to charge the battery
The option to disable charging only applies when the BTR5 is running. When the BTR5 power runs out the OS exits - stops running - and the USB cable if still connected will charge it back up. Don't forget to re-enable charging when you power it back on.
We've seen people panicking because their precious new BTR5 was "bricked", it's not, it's out of power
You can also set the BTR5 to prefer USB or BT, so that when you unplug the USB the BTR5 will immediately connect to BT for a "seemless" transition from plugged in to BT connected. That's how I set up my BTR5's, very handy.
I've got a few BTR5's and a BTR3k, so I'm distributing my unplugging across all of them, so it will take "3x longer" to wear them out. One BTR5 - the "Blue Sky" special edition still NIB, I should really unwrap that one and make sure it works. So far no port failures. I also use a variety of headphones / IEM's with 3.5mm/2.5mm so I'm further splitting up the unpluggings across those 2 ports.
The BTR3k is also a nice choice. I use it when I don't want to mess with the BTR5 screen - when I can't look away to use the buttons and screen to make changes. The BTR5 is fine - I can find the volume up and down easily, until I accidentally push the mode button and the volume controls are now working as menu scrolling pointers,
I like the simplicity of operation of the BTR3k - and although it doesn't put out as much power I have used the BTR3k to drive 600 ohm headphones out it's 3.5mm port, the BTR5 sounds better for that though.
I also use a
Hidizs S9, that has no controls on it and I control the volume via the phone / Windows, it also has good drive and is a good alternative when the
FiiO BTR5 /
BTR3k are out of stock, when making recommendations to others on what to try. Hifigo always seems to have them available (they are in Chia) and expedited shipping usually gets here in 3-7 days.
On Amazon when they are in stock I try to purchase from FiiO as a direct seller through Amazon - if listed - so I can get direct warranty, from Hifigo they handle the warranty.
So far no warranty claims for FiiO hardware
