Dear friend,Can the BTR11 be used over USB like the BTR3K?
Hi, no, the BTR11 could not work as USB DAC.
Best regards
Hi, is the wireless interference from smartphone? What IEMs you tried?I've just received my unit and I'm experiencing issue with it.
During idle/when sounds are not played, a constant buzzing and hissing sound can be heard in the background.
I've tried using different 3.5mm cables and other earphones however, they all produce the same buzzing/hissing sound.
Is there a way to fix this or is this a defective unit?
What is the DAC output maximum depth and sampling rate on this model?
Equipped with the latest BES2700 Bluetooth chip from Bestechnic, supporting LDAC and Bluetooth 5.3.
At an affordable price, this Bluetooth headphone amplifier offers HiFi-level wireless audio quality!
Compact and as long as a pinky finger, weighing only 12.5g and featuring an independent headphone amplifier with a maximum output power of 45mW.
The BTR11 combines compactness and power, breaking the competitiveness of Bluetooth headphone amplifiers in this price range!
Built-in high-sensitivity omnidirectional microphone supports noise-cancelling for calls. Music playback could last for up to 15 hours.
Worry-free calls and music playback all day, a versatile model in the affordable Bluetooth headphone amplifier category!
The BTR11 is available on our AliExpress Official Store. Click the link to take it home right away:
https://www.aliexpress.com/item/1005007827626208.html
Hi, i think you mean USB DAC to your PC? BTR11 doesnt support USB DAC decodingWhat is the DAC output maximum depth and sampling rate on this model?
No, I mean the BES2700IHC chip has LDAC + DAC inside, but the datasheet doesn't mention the bit depth and sampling rate capabilities of the DAC processor.Hi, i think you mean USB DAC to your PC? BTR11 doesnt support USB DAC decoding
Yes, BES2700IHC chip receive data via LDAC, then submit the data to the DAC inside to exchange it to anolog data. DAC inside can handle 32 bit and 384kHz data.No, I mean the BES2700IHC chip has LDAC + DAC inside, but the datasheet doesn't mention the bit depth and sampling rate capabilities of the DAC processor.
Even if the LDAC can transfer 24/bit 96Khz, the analog output quality still depends on the DAC capabilities right?
