FiiO Willson
Sponsor: FiiO
Before the signal enters the Bluetooth 8675 chip, it will undergo preliminary processing. The principle of processing is to choose the corresponding sampling rate according to the Bluetooth format selected by the user, and if you choose LDAC, the maximum is 96k sampling rate. If you choose aptX, the sampling rate may only be 48k.Thanks!
Can you confirm if it gets 24/192 input, will it be compressed before bluetooth transmission? Trying it right now over optical, I get sound with cracking and popping. Is this due to optical limitation, or will there be no difference if I use coax cable instead?
The processed signal is then given to the 8675 and then output.
As for the sound problems you say connected to the Optical, I suspect that there is a high probability of problems with the Optical signal, you can try the Coaxial input, if the Coaxial input is fine and the Optical input can not, then you can be sure that there are some problems with the optical input device
In our research, we found that the Optical support more than 96k sampling rate, may not be very stable
You can communicate with me directly by private message or Twitter, which will be more efficient
