HiFi Oasis
Correct, Windows just detects it as a USB audio device. No drivers needed.Sounds good. Was it just plug and play without installing drivers?
Sony Music center on your phone? Try to turn off phone's Bluetooth. Also it's 80% that "cracking" caused by your phone. Especially you said that it's ok with the youtube app.arh, I just tried with my old PC, plug n play and it works, but 1 problem like some reported, there is cracking sound in the music, pfffff. Fiio, pls fix this too.
It's very strange, with youtube, there is no cracking sound. But with Sony Music center app, the cracking sound is very obvious, maybe something to do with hi-res music.
On my PC with windows 11. I have tried googling, it seems to be a common problem with USB audio device with windows. So many solutions posted, tried several methods, updating drivers, bios, power management etc. Still crackling, think I will just use it with ps5 pro at the moment.Sony Music center on your phone? Try to turn off phone's Bluetooth. Also it's 80% that "cracking" caused by your phone. Especially you said that it's ok with the youtube app.
Please read / advise!
iPhone 15 Pro Max - Fiio BT11 - psb m4u8
1. I open the Fiio Control app, insert the BT11 to the phone, connects it via bluetooth. ✓
2. Enter pairing mode on psb m4u8 and BT11 and pair them successfully. (so far so good) ✓
3. Doesn't playing music, BT11 lights up green.
4. I connected a Macbook M1 pro, Windows 11 PC, and iphone 14 - all devices play sound perfectly, just not the iphone 15 pro max.
After some time I found an unexpected solution. I connected the iPhone 15 Pro Max via two adapters and the sound appeared. It turns out that Fiio bt11 does not work in USB 3.0 mode, but only in USB 2.0.
Help me find a solution to this problem.
It looks better... The silver looks kind of cheap...This is an odd question, but any reason the black one is more popular than the silver one?
So maybe it should work with my Stax S5 without problems?I bought BT11 from the date of release. There were no special problems with the initial setup. It works almost perfectly. The connection is stable whether it is 3 meters or 5 or more, no interruptions. Codec aptx Lossless (green light). TWS Creative Aurvana Ace 2 (aptx Lossless), Edifier Stax Spirit S10 (aptx Lossless), phone Nothing Phone 1.
I think that maybe the quality of the bluetooth module of both the phone and the headphones matters. With this phone I had no problems with wireless sound at all, on different devices...
I continue to enjoy and wait for the BT11 update.
* The only drawback now, as I mentioned before, is a crackle when starting playback, but for a few seconds. So I think they will fix it...
Interesting. Mine works great as well and I never heard this crackle. LDAC and AptX (350) only, so this might be a codec thing.I bought BT11 from the date of release. There were no special problems with the initial setup. It works almost perfectly. The connection is stable whether it is 3 meters or 5 or more, no interruptions. Codec aptx Lossless (green light). TWS Creative Aurvana Ace 2 (aptx Lossless), Edifier Stax Spirit S10 (aptx Lossless), phone Nothing Phone 1.
Yes, it is plug and play. No drivers required.I’m getting my own copy in a few days. I only want to use it for Windows. Is it plug and play or do I need to install drivers?
