[FIIO BT11] Portable High-Res Bluetooth Transmitter Is Officially Released!
Sep 1, 2024 at 7:03 AM Post #32 of 1,281
YES,if you got a right Lightning to Type-C adapter, it can work.
Hi
Can you please elobarate which adapters will work for example?
Such as ddhifi.
Coming from Sennheiser BT05, it won't work with all lighting to USB-C adapters I have tried besides clumsy Apple camera connection kit plus powerbank.
Otherwise a message is displayed: this device is consuming too much power.
So can the FIIO dongle work with lighting adapter without an additional powerbank attached?
Sep 1, 2024 at 8:59 PM Post #33 of 1,281
Hi
Such as ddhifi.
Sorry, I only bought this one ,and it can work,
Maybe you can find one with the same functionality as this one, which should be fine
https://item.jd.com/100052746136.html
Sep 3, 2024 at 12:54 PM Post #36 of 1,281
Some of my LDAC headphones need AAC for multipoint, or it gets choppy real fast. So I need the AAC codec while I multipoint in my work hours. I plan to use it with my Windows PC, that's why I need it badly. AAC also gives the longest range inside my house, better than SBC. I also need the aptX lossless and/or LDAC without using two bluetooth adapters on the same PC.
Sep 3, 2024 at 10:11 PM Post #37 of 1,281
I still have headphones that use AAC codec. Should I expect AAC added in an update or look somewhere else?
Very few dongles do AAC launches nowadays, not much commercial value
Sep 10, 2024 at 1:42 AM Post #41 of 1,281
Can work with FW3 in LDAC format.
Now BT11 does not support the call function,
But we have this feature reserved.
It is expected to be supported in subsequent upgrades to transmit the sound from the headset to the phone via Bluetooth when a call comes in
Clarify please: If I have BT11 plugged into my PC and it is transmitting LDAC to a TWS earphone, if a phone call comes in I can accept it on the TWS and BT11 transmission will halt, correct?
Sep 10, 2024 at 3:38 AM Post #42 of 1,281
Got mine today. its great. Using Sen mtw4 and a samsung device. USB audio player Pro and Tidal. very noticable increase in detail and clarity.
Its smaller than I thought it would be also, really nice surprise there. Great Job Fiio.
Are you actually bought it? Bought from China so urgently?
Outside of China, we haven't started selling it yet, we want to wait for a firmware upgrade before making it available globally.
Sep 10, 2024 at 3:38 AM Post #43 of 1,281
Hello! Is there a chance that the FiiO BT11 will go on sale this year/century in official FiiO store or aliexpress? :)
Yes, will be realease all over the word at the end of Sep, or Oct
Sep 10, 2024 at 3:40 AM Post #44 of 1,281
Yes,
The phone is set to the highest priority :beerchug:
