[FiiO μBTR ] Bluetooth receiver,Qualcomm CSR8645 Bluetooth chip,independent local volume control,9 hour battery life(Refurbished μBTR Promo on FiiO AliExpress Official Store now)
Dec 17, 2018 at 2:13 PM Post #31 of 66
Hi, just want to make a question.
I have a yamaha amp and I want to ad one bluetooth receiver in an aux channel for send music via bluetooth, do you think that the ubtr is a good option or I have to go up with other models??
I only want to send music with ipad, iphone or android nothing too much purist in terms or codecs or similar....
Thanks in advance..
Dec 17, 2018 at 3:11 PM Post #32 of 66
Thanks in advance..
I think the μBTR would be a good solution, particularly because you're talking about iPad/iPhone and it has AAC, which sounds very good, and AptX for Android, which is also good (although AptX HD is better). I'm very happy with the sound quality. You may have to play around with the volume, since it doesn't have a line-out function. It's a good value, and I'm not sure what the more expensive units would have that you need, since Apple devices don't have LDAC.
Dec 17, 2018 at 4:30 PM Post #33 of 66
Hey! Thanks for your response! I think I'll get the ubtr! Only for information purposses, do you know if the btr3 or the btr1k comes with a line out? Or no one of those bluetooth receivers have it...? Thanks!
Dec 17, 2018 at 5:09 PM Post #34 of 66
None of them have a true line out, but I think all of them have independent volume control, so you'd probably just crank it up. You could probably even leave any of them plugged into a charger with the right cord (USB C for the later two, not sure about the BTR1).
Jan 19, 2019 at 4:06 AM Post #36 of 66
My review on FiiO uBTR is live now!
I actually made a 4-Way review on BTR3, BTR1K, uBTR and FiiO FB1.
The Audiophile-Heaven link has all of them together, while on Head-Fi, I posted each of them individually.
https://www.audiophile-heaven.com/2019/01/fiio-bluetooth-freedom-review.html
https://www.head-fi.org/showcase/fiio-µbtr-ubtr-microbtr.23361/reviews#review-21472
Apr 22, 2019 at 8:49 AM Post #41 of 66
I loved my uBTR but since yesterday it won't connect anymore. It just flashes quickly red and blue and although my phone and tablet can find it with Bluetooth it just won't connect. Also tried to reassign by simultaneously pressing both volume buttons but to no avail. Is there a way to hard reset the uBTR?
Apr 23, 2019 at 5:20 AM Post #42 of 66
Dear friend,
Please try to forget the uBTR from the Bluetooth devices list in your mobile phone, then reconnect?
Best regards
Apr 23, 2019 at 6:34 AM Post #43 of 66
Dear friend,
Best regards
Thanks for your reaction. I've tried that and it didn't help. It also won't connect to my tablet either. It can be found but the uBTR keeps blinking red and blue and the phone/tablet just give the 'cannot connect' warning. I do have another uBTR though and that connects perfectly.
Edit: it works fine again.
Jul 19, 2019 at 3:56 AM Post #44 of 66
Hello. Thanks for the review. Can i use the fiio BTR3 to play PC games on my laptop and stream the audio wirelessly to my wired Samson SR850 headphone? Does Windows output Game audio through Bluetooth to an external device? If yes, will game audio be degraded over this setup?
I am having hard time finding answers to these questions. Thank you!
Jul 19, 2019 at 4:51 AM Post #45 of 66
Dear friend,
The BTR3 could not support Bluetooth headphone. It is a Bluetooth receiver instead.
Best regards
