- Aug 9, 2006
Indeed, this is a poor design decision. But it affects all BTR series Bluetooth amps/DACs.The layout is backwards to me, you have to use the - button to go to the next track.
Uh, no, it's the right decision for physically-intuitive playlist handling. Look at the playlist or playback queue: the next track on the list is below the current track, so you'd press "down" to get to it. That has nothing to do with the "+" and "-" symbols on the buttons - FiiO may as well not even print those symbols there and avoid the confusion. "Up" is "volume-up" when you're controlling the volume, but it's "previous track" when you're navigating the playlist, because we read lists by going down from item to item. Both are intuitive once we forget about the "+" and "-" symbols. The only use for those symbols is to remind you which button is which in case you attach your BTR receiver to your shirt in an awkward orientation or even upside-down.Indeed, this is a poor design decision. But it affects all BTR series Bluetooth amps/DACs.
Oh, right! My bad. I just realized I thought it was OK on the BTR3 but I had only ever used it to control the volume. In fact it is backwards: when clipped upright to a shirt the "up" button goes down in the playlist, just like Android's dumb system setting you can enable for the phone's volume buttons. And FiiO could solve it so easily and stop confusing everyone by just labeling the buttons "up/down" instead of "+/-" and make them function accordingly for both volume and playlist.If that were the case, then the BTR3, which orients the clip the other way so that Plus goes 'down' the playlist and minus goes 'up' the playlist when clipped onto something, would be opposite. It is bad design.
Dear friend,So I now have a phone w/o headphone jack. Not a fan of the dongle, it's easy to misplace, lose and forget.
So I was thinking I would either get one of the fully wireless TRN T100 / MPow T5
or
Fiio BTR1K, advantage making all my headphones bluetooth, dedicated amp.
Considering this will only be used with my phone when I am out and about, hmm pondering which way I should go.
or
Hi guys,
Excuse my ignorance but I can’t find this info anywhere. Does the BTR1K add anything to the BTR1? Doesn’t it have Aptx HD and/or LDAC for example? Or is that limited to the BTR3?
I thought the BTR1K was newer and therefore better specced but I could be wrong.
