Using galvanic isolation between computer
Yes, I'm asking, because it's a roundabout way to assess RFI.
If you really think RFI is a problem, you don't need Fidelizer or galvanic isolation DAC to test that. You crank up the CPU to max with a simulated work load and use a RFI detector, which will give you a reading in dB.
Archimago has already measured the noise coming over USB cables & even using his mediocre measuring equipment, he measures a 5 to 10dB drop in all noise (it's not just RF)
http://archimago.blogspot.ie/2015/05/measurements-corning-usb-3-optical.html
First you discredit Archimego, then you use his data.
As I said if his amateur pseudo-measuremnts show a reduction in the noise floor of 5-10dB, who knows how much more a real measurement would show?
You may have missed it, but the USB noise prior to reduction was already at or below -120db. That's way below the audible noise floor.
Who said anything about hearing the noise floor directly? It's about the effect a fluctuation ground noise spectrum can have on the sensitive analogue circuits inside D to A converters - the clock & the voltage or current references - it's the secondary effect of noise fluctuation on these processes
Not that any of that is relevant to the discussion of Fidilizer changing process priority and processor affinity.
As I said, a possible mechanism for its effect is changing the noise spectrum of the computer
