It's probably working OK for you then.
To avoid problems, you could simply make the captured WAV files available instead of the diffs.
I predict you'll find a null result, provided you don't screw anything up. Your test method is equivalent to using a "perfect" DAC, with zero distortion and zero susceptibility to jitter and noise on the bitstream from the PC to the DAC. Perfect DACs don't need PC optimisers or USB isolators etc.
That's correct. And it also avoids problems with real audio hardware interfacing. It's pure software experiment. However, this doesn't cover problems related to interfacing with real audio hardware but we'll leave that for now.
OK. I finished the experiment using the following setup
OS: Windows 10 (No Fidelizer Pro installed)
Sound Card: VB-Audio Virtual Cable (Max Latency: 1024smp)
Playback: Foobar2000 with no ReplayGain, Kernel Streaming output, 50ms Buffer length, Playback optimized
Record: Audacity with Windows WASAPI as Audio Host, 50ms Audio buffer
Test track: Astrognosia: Aquarius – Vannmannen (CD-resolution) from 2L High Resolution Music .:. free TEST BENCH
Procedures
1. Record before Fidelizer optimizations
2. Use Fidelizer with Extremist optimization level (no services to keep), exit all programs
3. Record after Fidelizer optimizations
4. Use DiffMaker to compare each recording with reference file from test bench
5. Compare between recordings (untouched with different samples)
6. Compare between aligned recordings (same samples)
7. Listen difference track for audible sound
Test Results
1. I recorded before and after files without issues. No stuttering and I'll use before recording as main file so after will be slightly longer.
2. I used DiffMaker to compare before file with master recording and got this result
parameters: -1.596sec, 0.001dB (L), 0.002dB (R)..Corr Depth: 79.2 dB (L), 72.2 dB (R)
0.00xdB is still in marginal error and inaudible. I consider this as null result. I tried my best to optimize software and driver before recording but still can't get 0.000dB. Moving on
3. I used DiffMaker to compare after file with master recording and got this result
parameters: -1.852sec, 0.002dB (L), 0.003dB (R)..Corr Depth: 73.8 dB (L), 69.5 dB (R)
0.00xdB is still in marginal error and inaudible. I consider this as null result. I noticed 0.001dB increment but that is also marginal error from alignment. Moving on.
4. I used DiffMaker to compare reference file before with after file and got this result
parameters: -255.9msec, 0.136dB (L), 0.136dB (R)..Corr Depth: 36.0 dB (L), 36.0 dB (R)
Exactly 0.136dB for both channel? This is beyond marginal error and should be audible. This can't be null result. Maybe changes between recording has long delay to cause something like this. Let's try aligned tracks
5. I used DiffMaker to compare reference file before with after file using aligned source and got this result
parameters: 0sec, 0.026dB (L), 0.012dB (R)..Corr Depth: 50.1 dB (L), 56.3 dB (R)
Looks much better but it's still beyond marginal error. Some parts should be audible. This can't be null result. Maybe different recording has this level of marginal error?
6. I used DiffMaker to compare reference file before with before_again file using aligned source and got this result
parameters: 0sec, 0.027dB (L), 0.013dB (R)..Corr Depth: 49.3 dB (L), 55.6 dB (R)
Looks like marginal error between recording. And Left is twice loader after alignment. I'm using bit-perfect in the chain for both playback (Kernel Streaming) and recording (WASAPI). How come there's still such big marginal error like this? It looks fine with master file as reference, though.
7. I tried listening to difference tracks, I can't hear anything when use master file as reference but can hear faint sound from between recording files regardless of using Fidelizer optimizations or not.
Conclusion
Bit-perfect playback/recording can produce marginal error at range 0.01-0.03dB. Still need to investigate to make null result between recording. If you have any good freeware or configuration to recommend as alternatives, please post below and I'll check again tomorrow.
Regards,
Windows X
