krude
I think almost no one had old stock at that time. Got new oneYeah if you buy a brand new stock Wandla it'll have the voltage divider. If the dealer has old stock it wont
Cameron how does the 465 synergies with Wandla GSE ?465 is pretty damn fantastic
I use HQPlayer with the Wandla, but no DSD - PCM up to 768, and other settings according to GoldenSounds recommendations can look them up laterHas anyone tried DSD/HQplayer on the wandla? I can only seem to get it to do DSD if I check DSD over DOP. I can do DSD fine on Roon(not sure if Roon uses DOP?)
Edit: The way to fix this is to remove Wandla from Roon and just have it run HQPlayer
Specific recommendations for Wandla or @GoldenSound ’s general HQP recommendations?I’m
Thanks, that is also very good to know! But yes, specific hqp settings when using it with the Wandla, which included using PCM, but I’ve deviated from his preferred filters because I found them a bit too detailed and … maybe sterile.Specific recommendations for Wandla or @GoldenSound ’s general HQP recommendations?
I asked in another forum what the equivalent HQP filers were to be close to the Wandla ones if you wanted to take them to 768kHz and @jlaako said their filters are finely tuned for Wandla, but closest are: poly-sinc-lp/poly-sinc-mp for apodising linear and minimum phase respectively and poly-sinc-gauss for gauss filter.
I missed them, could you share or link to them for me to try?…yes, specific hqp settings when using it with the Wandla, which included using PCM
I don't think I can link to a comment on a facebook post in a private group, but to quote him:I missed them, could you share or link to them for me to try?
my personal recommendation would be 768khz, sinc-Mx or Sinc-L (try both see which you like best), 32 bit TDPF dither
ThanksI don't think I can link to a comment on a facebook post in a private group, but to quote him:
