Feliks Audio ENVY
Nov 5, 2022 at 4:46 PM Post #1,081 of 9,958
Any recommendations on Socket Savers?
Nov 5, 2022 at 4:46 PM Post #1,082 of 9,958
I have adapters from 'Glenn' of amp building fame and still need socket savers with the 6F8G's
Hmmm. I see which socket savers are the best. I got to order some. Any socket savers for the power tube side as well? Thanks.
Nov 5, 2022 at 4:49 PM Post #1,083 of 9,958
Yeah, the Envy sockets are deep and do require a socket saver with the 6F8G's / adapter.
Even using 6SN7 / 1578 I also use socket savers or I'm pulling the tubes out with mostly glass and very little base.
I would really like to know the engineering principles behind having recessed sockets, just makes things awkward. And we want to see the graphics on the bases.
Nov 5, 2022 at 4:53 PM Post #1,085 of 9,958
I got mine from Deyan on this forum.
Nov 5, 2022 at 5:27 PM Post #1,087 of 9,958
It certainly looks better to me with recessed sockets
Nov 5, 2022 at 5:51 PM Post #1,090 of 9,958
In terms of heat dissipation is not helping and without socket savers you have to pull out the tube by grabbing from the glass not base.
Well going by the pictures the tubes aren't so recessed that you can't pull at the base anymore. Obviously not as easy as when they are not recessed at all.
The good thing is, if it is recessed and someone doesn't like it, he can use socket savers to fix it.
If they aren't recessed and someone prefers them recessed, there's nothing he can do.
Anyways, I agree that having them not recessed has more practical purpose.
Maybe it's easier to manufacture that way, with having the wood they way it is.
Nov 5, 2022 at 5:54 PM Post #1,091 of 9,958
Yep. I agree with you. With the remark that purists avoid unnecessary connections like socket savers which might be additional point of failure/hum/sound degradation based on the quality of the saver. In my case I would always prefer to have top mounted sockets but I also exchange tubes often which might not be the case of Envy.
Nov 5, 2022 at 7:30 PM Post #1,093 of 9,958
Due to these new developments I adjusted my plans. Instead of saving up for the Bog Oak Version (+3k, so ~10k total) I decided to go with a regular Walnut Version.
I pulled the trigger just now, so the amp should be with me by end if dezember or early january.
PS:If someone needs a +1 for SR Purple fuses im Europe, I'd be interested for ~100€ (if the Deal even applies to european customers)
Funny how it took me nearly a year to finally pull the trigger.
Congratulation for the decision. Heavy one.
The year is perhaps because you are disciplined (mostly 😉).
Availability is anyway less than half a year.
Nov 5, 2022 at 9:23 PM Post #1,095 of 9,958
I feel like between @paradoxper and myself, we're single-handedly trying to keep the global economy going by stimulating spending on tubes from around the world...
