Feliks Audio ENVY
Jan 16, 2025 at 7:42 AM Post #9,001 of 10,033
Medium and high gain are not that different, medium gain should be lower and low gain should also be lower. You mostly only get a higher noisefloor with high gain. Solution: Don't use high gain, use mostly low gain, for hard to drive stuff switch to medium.
They do differ however. Medium has 8ohm and high is 20ohm in output impedance. I prefer the sound of high gain even though it’s only 2db volume difference from the mid
Jan 16, 2025 at 8:28 AM Post #9,002 of 10,033
I may have had a bit of 'wobble' as illustrated in Ex video.
I did send my amp to Upscale Audio to get a new transformer last summer and Feliks included a new transformer cover and some other parts for the repair / replacement of the transformer.
Perhaps the tech replaced or tightened these 2 knobs or replaced the underlying switches?
What I do know is these are both rock solid with no 'wobble' or play whatsoever......... today!
You can never discount luck and I suppose I'm lucky.
Jan 17, 2025 at 11:34 AM Post #9,011 of 10,033
I asked Feliks whether Envy was OK with a 6V input and they side it will be fine but 2V is preferable 🤷
Is there even a high end DAC without preamp that has a (fixed) output of 2v or less? Looks to me the use of a preamp (module) is the best option.
Just ordered them, Ill let you know -> no matter what it will be bliss going from a defect WE300B to all working tubes plus the Brimars -> probably wouldn't have gone down this upgrade route if everything was working from the get go haha :)
I made the experience that the 300Bs make the most difference. To be honest, I bought the Brimar 1988s (also brown base, transparent ones) mainly because of looks 😅 But I got a very good deal and only paid 200 EUR for a used pair. NOS Red Base RCAs incoming, as well. Also bought mainly for looks and as spares for the Brimars. I don’t expect much of a sonic difference, either.
The problem with comparing tubes is audio memory. It obviously takes a long time to change tubes and listen again if you don’t have 2 equal amps with different tube settings plus driver tubes differences are not that obvious. That’s why it is great @Exekuhtor was able to compare just like that.
All the experienced tube fans say that the Brimars are good, so you will be fine :)
Voltage might not be a problem explicitly, but the gain is - mid/high are so vast that the pot has to be turned all the way down (8 o’clock!), which hurts the sonics and dynamic range. It’s a shame that is the most generic potentiometer, not some nice stepped one. With May directly low gain would be okay volume wise with abyss, but it chokes. Now I just set up Envy to 2 o’clock high gain and control with the remote from a chair
That is one reason why I wanted to have the Spring. It has the option to be upgraded with a top notch preamp module + a great remote control. I sit 2m+ from my system so a remote is perfect for me.
That's one of the three flaws of the Envy.
The potentiometer makes the unit too loud too quickly - people almost only use the first third. Solution: Use a preamp.
The gain / input knobs are wobbly. Solution: Don't touch it.
Do you use your Immanis on Mid gain, too?
So, unlike some others here, you are not suffering from knob wobble.
I belong to the members with the beautiful knob wobble feature! Honestly, who cares? It’s not super tactile but therefore it represents a perfect analog character!
Jan 17, 2025 at 11:39 AM Post #9,012 of 10,033
M21 (and I'm guessing M1/M3 but I'd need to go check spec) is 1.2v@+6dB with RCA.
Jan 17, 2025 at 1:09 PM Post #9,014 of 10,033
Jan 17, 2025 at 2:31 PM Post #9,015 of 10,033
Sadly keeping the OG Envy for just A/B testing tubes was out of the question.
Aye.
Unveiled, CC (allthough here i might think mid makes it sound a bit better? I need to check that more), Valkyria on low, 1266TC and Immanis on mid.
When i think about it: That is the ultimate power move: Having two of the exact same tube TOTL amp just for directly comparing your tube rolls...
