- Jun 26, 2012
Hi Howie13,
According to my understanding the Elise is wired in such a way that what counts is the total current draw of all four tubes. As an example, if you have the power tubes on external power, you should be able to use a pair of 6AS7 as drivers, drawing 5A together.
In the past, in my Little Dot days, I was using an external 12V power supply for the power tubes with a voltage regulator. For reasons that I do not understand, there was a different amount of voltage drop depending on the tubes I used.
I measured the actual voltage reaching the tube pins. To get 6.3V at the amp socket, I sometimes had to set the voltage regulator to 6.4V, 6.8V or 7.1V, all depending on the type of tube that I used.
All this may be academic, since the tube specifications usually allow for approximately a 10% difference in the tube voltage.
As for hum, it seems that most people attribute the hum to grounding problems.
I am intrigued by a Faraday cage but never got to try one out.
It was a makeshift Faraday cage, thought up by an inventive, imaginative person on the Ember thread (not by me).
It's an IKEA utensil container, inverted over the single 6A6 - fortunately it just fits nicely, and then an earth wire is hooked into one of the holes in the container and connected to an earth point on an old America Audio equaliser on which Ember is resting. The equaliser isn't in use and doesn't even need to be switched on, but it does need to be plugged into the mains socket by it's earthed 3 pin UK type plug. Works a treat. Most gratifying to go from loud hum to total silence with the touch of a wire.
