UntilThen
- Jun 16, 2015
Nothing like a bit of bluesy rock by good ole Keith on a Sat afternoon.
That's a beautiful car. This was my ship. Memories are fading.
I found a sleek deal on Mullard 6080's for only 30 pounds each here, and he seems to have a lot available. Would any of you say this is a good value, and how they are different from other 6080 brands? Thanks!
In my environment, Elise still has a hum at very (very!) high volume.
I'm still chasing a hum-free setup, (including at stupidly high volumes i will NEVER use!)
If I disconnect the cables (RCA) from the DAC, Elise is dead silent at %100 volume.
If I plug my HPs into the HP out from the little Grace DAC/amp, pause the music, turn volume to full, it's dead silent.
So I'm a little confused.
Is it the cables picking up some interference - or could it be the Grace DAC/amp adding it to the RCA out (but not the HP jack?)
Should my next step be better quality (better shielded) RCA cables?
If so - any links to some that aren't stupidly expensive?
Thanks guys.
@UntilThen - The DAC/amp gets power via USB from the PC, with an optional USB to power point. With the optional one connected it's meant to get all it's power from that one and signal (only) from the PC. That connection is a 2 pin plug (no ground) only. Unplugging it so that the DAC is getting both power and signal over the one USB doesn't seem to make any difference to the hum from Elise, and the HP output on the Grace is still hum-free.
Moving my source (full tower PV) to another room will be a PITA - but will move the DAC and Elise to a different room and try with a longish USB lead. I could also try with a laptop as source.
I have some 6080s and some EL3Ns and adapters coming "strictly for troubleshooting purposes".
@HOWIE13 the DAC/amp volume controller does indeed alter the output to the RCA jacks. I'll see if I can get an RCA male to 6.3mm female cable and test that way also.
My sympathies. Hum of any kind can be annoying.
6xEL3N has become silent for me again. With no music playing and volume turn to max and headphone on, I'm getting total silence. I do wish every Elise owner have this experience too.
Btw this 6 pack is sounding so good and hardly any heat after 4 hours, I'll just let it stay in.
That brings me a question that I've always wanted to ask but usually forget.
If you are tube rolling several drivers to make comparisons with the same power tubes should you switch off the power to Elise each time you change the drivers or do you just pull the drivers out of their sockets and replace them with the next ones without switching off?
I've always done the former but I've concerns that constantly switching on and off could damage or shorten the life of the power tubes, which of course may be my much cherished and very expensive 5998's.
OMG Howie I almost choke on my spaghetti. !!!
Don't you even think of pulling out the drivers without switching off Elise. One, you'll burn your fingers. Two, you'll see the 4th of July fireworks.
You can get a nice pure musical sound at low volumes.
