UntilThen
- Jun 16, 2015
If I want to tune the sound into more lush and warm sound yet keep all the sonic, clarity, high-speed dynamic features, which tubes I should go for? I'm going to roll some EL3N with 6080WA next week as UT recommends. @UntilThen I'm also open to other suggestions if someone has the similar experience.
We need a reference point, so we'll go back to stock tubes. Tung Sol 6SN7gtb re-issue and Svetlana 6H13C gives a warm and lush sound with a healthy bass quantity but is a bit recessed with details. Of course this depends on the headphones used. Just take for instance, using stock HD650 and Beyer T1 G1. Those 2 headphones are very contrasting and will sound different with stock tubes. We've not even factor in in your source, which for most people would be the DAC or some, the turntable and cartridge.
Replacing Svetlana 6H13C with Mullard 6080 will produce a sharper and brighter sound. You'll hear more details but you'll lose some warm and lushness. Now replace the Mullard 6080 with Chatham 6AS7G will dial back some of the lushness and warm you're seeking. 5998 isn't too warm or lush but has energy in abundance and has more lushness than the Mullard 6080. 7236 is a leaner, tighter version of 5998.
Finally if you replace the stock 6SN7 with EL3N or ECC31, you'll get not just a warmer and lusher tone. You'll also get a different perspective of the musicians. You're closer to them and the sound will seem to hit you like a wall of sound.
ExaSound E12 uses ES9018S DAC chip, so I'm not surprise, you are now wanting more warm and lushness.
Good luck with the tube rolling and don't tune too much. Find a compromise and be happy with it and just enjoy the music. Nothing's perfect and that applies to our ears too.
