Feeding External DAC via Laptop's USB port
Feb 16, 2009 at 8:36 PM Post #33 of 40
Yes it does.
Is the DAC connected to your computer and turned on? Does the computer react when you plug it in (meaning: does it registrate that a device has been pluged in?) Should pop up a little notation when you plug it in.
If nothing happen, try opening up "device manager" and see if there is any problems with the compability. (reply if you dont know how to do that)
Feb 16, 2009 at 8:51 PM Post #34 of 40
Originally Posted by paara /img/forum/go_quote.gif
Yes it does.
Perhaps some (even possibly great) progress. I plugged my DAC into my laptop's USB port and it was recognized and soon a little window popped up and said it was installed and ready to use. And shortly after that my newly-installed SATD included in my list of playback devices a USB Audio CODEC! I'll now give it a try and report back.
Feb 16, 2009 at 9:27 PM Post #36 of 40
MANY THANKS YOU GUYS. THAT WORKED PERFECTLY! I NEEDED TO HAVE MY DAC TURNED ON AND PLUGGED INTO THE LAPTOP'S USB PORT FOR IT TO BE RECOGNIZED AND INSTALLED AND THEN HAVE THE NEW SOFTWARE LIST AND SELECT THE APPRROPIATE USB CODEC. YOU GUYS (AND THIS FORUM) ARE GREAT.
Feb 16, 2009 at 9:30 PM Post #37 of 40
Glad to help
And thaks to linuxworks I am able to burn an even bigger hole in my wallet
I am thinking of getting a CIAudio VDA-2 DAC, if you guys dont have any suggestions for me.
It is cheaper then the Benchmark DAC1 and supposedly as good as it.
How do you like your Headroom dac ascherjim?
Feb 17, 2009 at 1:10 AM Post #38 of 40
linuxworks, you are a golden god, I expected this thread to be a nightmare when I came back to it
one thing I want to throw out, S/PDIF is a digital communication standard, TOSLink specifies an optical connector standard for transfering S/PDIF, they are the same thing in a manner of speaking (kind of like, a 512TR is a sports car, a Ferrari is a sports car, a 512TR is a subset of a Ferrari, make sense?)
the VDA-2 is an amazing DAC for S/PDIF to analog, BUT, very expensive if you'd like balanced output, I would suggest looking at Cambridge Audio's DACMagic (I'm even a CI fan, and can't suggest the VDA-2 after DACMagic) as its cheaper, and comes with more inputs and XLR balanced outputs already installed, PLUS, the holy grail of features to me, digital passthrough
beyond that, linux basically said everything I was likely to say, so, yeah...
I feel, less needed
Feb 17, 2009 at 1:54 AM Post #40 of 40
Glad to help
I like all the Headroom products I've had and upgraded from over the years. The DAC I use is an older model no longer being manufactured but offered on a great sale by them last year. It can run on batteries in addition to mains power, which the newer replacement model can't. It is therefore useful for my taking on trips with me when I want to travel light. Hence, the main concern behind my initiation of this thread, to have it work with my laptop and a portable, battery-operated headphone amp.
