hoichi
- Aug 23, 2012
Seconded. Exactly for the reason stated by zzffnn.
James,
Thank you for your hard work on X3. Is it possible to add parametric EQ to X3 through firmware update?
Parametric EQ can nullify specific peaks/valleys of headphones (rather than changing entire treble like what the current treble EQ does). Some headphones, such as your Beyer DT880s (which have a bell-shaped treble peak centered at around 8500 Hz), would benefit from parametric EQ as much as the existing treble/bass EQ.
