Mr.Radar
- Apr 6, 2004
This is definatly the best route. "External" HDDs sold for 1.5-2x the price of an internal HDD of the same speed and capacity is generally just the internal version of the drive in a $20-40 plastic enclosure.
That's not necessarily true of today's external HDDs. Check out this enclosure review where they compare IDE inside the computer to USB via the external enclosure, and find only small differences. The external enclosure was still slower, but it wasn't as slow as you claim enclosures are.
My Seagate 7200.7, which is suppost to run pretty cool, requires a fan to keep from going over 55*C (pushing the limits of it's operational temp rating), and that's in a big steel case with lots of room around it. Most external enclosures are made entirely of plastic (at least on the outside) which is a poor conducter of heat and are designed to rely on their fans (often noisy 40mm fans) to prevent the drives from overheating.
If you're looking for silent then Samsung is the brand to get. Their drives are very quiet (not to mention fast). My Seagate makes a quiet but annoying high pitched whine sometimes (apparenly a common problem) and my Western Digital 80 gig drive was way louder than the Seagate.
EDIT: Quote:
Windows XP (and I think Windows 2000) as well as Mac OS X and Linux (with USB-Storage support available in the kernel) all support USB storage devices with no drivers. Windows 98 and previous Mac OS versions require a driver to be installed, but other than that no software is necessary.
Originally Posted by bLue_oNioN Buy a Seagate or Samsung HDD along with an HDD enclosure from Newegg and you're good to go. This way, you avoid the gross markups with packaged external HDD gimicks. |
Originally Posted by ReasonablyLucid External harddrives are SLOW compared to an internal one. They are only useful for data storage of things that dont require a fast transfer. Like movies/music or just misc backup files. If you install a program on these it will crawl. |
Originally Posted by Talonz You won't need a fan. Also, most newer hard drives are much quieter then older ones that make grinding noises. Seagates are known for their quiet operation. |
Originally Posted by Judge Crandall Anybody know anything about Western Digital's 250gb? I'm thinking about this or a Seagate. |
EDIT: Quote:
Originally Posted by Mr.PD Does a person need some software to run an external drive? |
