Experience with Topping VX3 + Topping D30 DSD ?
Apr 25, 2017 at 2:31 AM Post #16 of 24
Hello
Have to look at my cables [ aka shoe box ! ] to check if i have any and if any would do.
Thinking of these
Edit : I just gave it a try with a 24/96 63Mo song from my smartphone . Well, it goes through either cans on the VX3 or DAC D30 back to speakers. Not much use tho 350Mo for 5 songs is exhausting my SdCard ;)
Still that's one way I consider feasible for my " heavy" digital tracks on my cloud or through streaming services (Qobuz/Tidal)
I don't have the adapter in my shoe box
Apr 25, 2017 at 3:00 AM Post #17 of 24
The outputs on the VX3 are like one of those for speakers with L & R channel, so cable should be 2 to 1 jack with split for the coax input on D30.
Apr 25, 2017 at 3:21 AM Post #19 of 24
Isn't like a fixed setup, I am still looking for a decent set of speaker. But is good to know there are possibilities.
Apr 27, 2017 at 10:38 PM Post #20 of 24
I was setting up the VX3 today, didn't hook up to the D30 but just listening to Bandcamp on my Nexus 6 via Bluetooth.
As soon I turned on the power I notice there are background noise, I suspect it was the receiver antena so I put my finger on the brass part and it stopped the noise. Is it RF interference or poor shielding? or maybe it needs grounding?
I used a headphone no speaker so I don't know if back ground noise will be more noticeable on speakers or not. Is that common problem with the VX3?
May 1, 2017 at 12:53 PM Post #22 of 24
I will try tighten the antenna and see if noise will be gone.
Jun 15, 2018 at 3:09 PM Post #23 of 24
Will the VX3 output to the speakers and the headphones simultaneously like the VX1?
Jun 16, 2018 at 9:15 PM Post #24 of 24
