chicolom
- May 3, 2008
Your missing out. All the best music happens above 15khz.
There's nothing thrifty about $400+ headphones. :\
So, listening to 19khz tones '"sounds awesome"?? Do dog whistles also sound awesome?
I'm 22, and I can only hear just under 15 KHz on a flat EQ. That's a bit distressing, since I usually don't like loud noises and steer clear of most noisy environments.
My ears are also a bit unbalanced at certain points across the frequency spectrum. Kept thinking it was an issue with my headphones 'til I noticed the exact same imbalances across ALL of my headphones...
Ultimately, no matter how good my headphones of choice get, the ultimate bottleneck in the audio chain happens to be my own two ears.
SoAmusing77,
You might want to consider your next audio "purchase" to be a trip to an audiologist. I'm not sure how much that would cost, but assume like +$100. You only get one set of ears, and if they're pretty good now you ought to do your best to keep them that way!
Some say that ringing in your ears is a sign of a frequency dying out. I have no proof of that though.
You're missing out. All the best music happens above 15khz. :basshead:
You're kidding, right? How high do your ears hear? Are those the sounds your avatar is yelling about?
How dare you correct my grammar! :tongue_smile: Who do you think you're?
My avatar is a shot of me listening to the complete and total sonic bliss of music that only takes place above 15khz - which you'll never hear! :evil:
<3
By the way, I changed my avatar a while back because you said it needed more explosions, but I never heard if it lived up to your expectations? I recommend looking at it big, the reflections on the wet asphalt are preeeetty.
I'll repost the comparison on your thread in just a bit, had a read through your first post and couldn't agree more with your comments regarding what works for each individual - it was that fact that drove me to really want to try MyEars, if everyone could come up with their own profile that works then it would be possible to have a baseline to work with in order to compare the other technologies with (ie if a custom MyEars profile is the best that surround sound can get for me then how does CMSS-3D compare for me, how does DH compare etc).
This would of meant that we got of put together some kinda MyEars profile repository for newcomers to try, they try each profile to find out which works best for them and then see what general surround sound tech worked best for the person who made that profile (so if MLE made one and a newcomer found that his profile worked best for them then they know that DH is the way to go). That way, someone who is new to the tech could pretty much gurantee it will work for them to at least some degree.
I tried out the video in your thread and it actually made the audio sound most similar to MyEars but without the distortion that I suffer from. I found another Youtube video comparing CMSS-3D and DH, this confirmed my thoughts about DH somehow making the soundstage sound wider to me - I would place CMSS-3D in between MyEars (ie smallest soundstage, worst audio quality but best positioning) and Dolby Headphone (ie largest soundstage, best audio quality and worst positioning) but would say that the audio quality differences between DH and CMSS-3D are EXTREMELY minor (ie in the video comparing the two I heard some very slight distortion when the window washing platform hit the ground on CMSS-3D that wasn't there with DH).
I would definitely say that CMSS-3D gives me better rearward positioning as well, I would say I get something like 240 degress of surround sound from DH compared to a full 360 from CMSS-3D but again this is only based on these two videos. Vertical positioning is also better in CMSS-3D for me though I'm guessing this is expected, I'm assuming from the '3D' bit that it's meant to simulate height in audio as well - the scene in the Crysis video where the shuttle aircraft goes overhead sounded better in CMSS-3D.
The video comparing DH and CMSS-3D: http://www.youtube.com/watch?v=L9ApNLMmeAs&list=UUqM-oxfSa1Z_BRgEq5amQUQ&index=21
^ Actually, I just noticed your posts in the comment for that video!!!
What I'm tempted to do now is scrap the idea of getting a DG and get a Creative card with CMSS-3D or SBX/THX surround built-in, that way I can do a direct comparison between that and DH over a variety of games/media. I can also try out Silent Cinema at some point though that will not be for several months, I have a Yamaha reciever that supports it back home but I always just used my actual 5.1 set-up with that. If I can make the soundstage a little bit wider from CMSS-3D (hoping my amp might accomplish this) then I would be 100% satisfied with that.
I'm assuming that the card the guy in the video is using supports both CMSS-3D and THX based on your exchange with him in the comments?
Creative's X-Fi Titanium HD offers both CMSS-3D and THX, but THX is only in "entertainment mode" instead of incorporated into Game Mode as it is in the Recon3D models. SBX is incorporated into the main audio suite of the new Z-series models too, in fact the software is arranged almost exactly like the Recon3D models (though the Z-series cards are of higher-spec). I haven't heard the Ti HD implementation for myself to be sure, but I suspect that it's different, and people speculate that THAT Crysis 2 video is set up wrong anyway. Mad thinks DH sounds unusually echo-y in that vid. I don't know for sure, which is why I didn't include the video in my guide, would be AWESOME if Nameless would post a sample with his Ti HD setup.
Just to say, I found Silent Cinema to have a good 360 degree soundstage, but the way it works isn't particularly subtle and typically has a fair bit of reverb. It actually does a good job of creating an even, wide soundstage, but THX on my Recon3D USB just sounds more refined and natural. Samples WILL happen someday, just... Sometimes I procrastinateLike right now, I want to type my next article, write a review for the E12 portable amp, make a YouTube video presentation of the AKG Q701, figure out how to record 3D surround samples, help an amp manufacturer with a project, apply at a Temp agency... But mostly I'm waiting to hear back from friends if I'll be included in a Superbowl party (US football/wussie-rugby championship).![]()
When I/we do make good samples of surround tech, I'll make a fresh "article" in this thread so people can reference it easily. That's the whole point of this thread... Making useful discoveries (and discussions) easy to access & use as reference.
Sorry this is long-winded but yea, it's been interesting so far. I can't believe there's not a better hardware solution between something like the MixAmp (the lack of DTS decoding hurts) and the BD Headzone that's > $1,000 ... or the Smyth Realizer.
You've piqued my interests with the THX/X Fi card. I hate to spend anymore money to try it but...it's tempting, especially with the RCA outs. The Xonar only has SPDIF so should I settle on the Asgard, I wouldn't be able to use it without a DAC. Mo' money...
DTS Headphone:X sounds interesting but all I've really read was fluff. Apparently it impressed the crowd at CES. I doubt we'll ever see it take off.
