Every level wireless, Nothing Ear 2 vs Sennheiser CX Pro?
Mar 25, 2023 at 10:19 PM Post #2 of 2
Looking to get a decent set of wireless buds for travel, with pretty neutral response. Anyone compare these? Anything else in the $150 range I should consider?
Linkbuds S would be my pick. Awesome ANC, very comfortable, and solid sound that is stored in the unit itself. DMS had really good things to say about the Nothing Ear 2 so they could be worth a shot:
If you don't need ANC and you're comfortable with EQ then the Fiio FW5 are also a great option - super comfortable and support PEQ.
