Eversolo DMP-A6 Network Streamer/DAC
Jan 12, 2024 at 5:22 AM Post #556 of 1,443
Last week I was able to compare the 2 streamers, Eversolo A6 Master Edition and A8 (out of box very new, not burned in).
Last but not least, I compared the devices with my AK240. Unfortunately, I couldn't tell the difference in sound. All 3 devices sound at a very high level. But there was no difference for me, whether bass or treble range, or even soundstage.
Unfortunately my very old Turntable (Thorens TD318 for 80€ :D with Dynavector DV20x2L) and Goldnote PH10 as Phonopreamp sounds a bit better (masterlu would say 1 district better :k701smile:, smoother and has more punch.
I really hoped that the 2024 devices would sound better than my AK240 from 2014, but that wasn't the case.
Jan 12, 2024 at 3:08 PM Post #562 of 1,443
I know, Im also not focalfan. Mine sound very sharp and thin,not bright & not harsh, difficult to explain, but it is the counterpart of my th900, in sum I am done with my hifi setup.
I am still thinking about A6 Master Edition
Jan 12, 2024 at 5:09 PM Post #563 of 1,443
If you want to save money, and don’t want to go for a A8, then A6 is the nxt best thing. You have the better amps and femto clocks. And later if you want to upgrade with a third party power supply that is possible to. Maybe not a A8 with AKM then, but hell of a good streamer.
A6 is quite noticable calmer and less sibilant in sound than the normal A6
Jan 12, 2024 at 5:28 PM Post #565 of 1,443
Why would it? did we just learn how to create high quality sounds in the last decade?
Jan 13, 2024 at 4:42 AM Post #566 of 1,443
A6 sibilant!!!! What chain do you use? I use A6 directly to my Klipsch the Fives (horn speaker!!!) and Sony SA-S1 (planar speaker!!!) and never get sibilance. If I stream to iFi iDSD Pro or TT2 - no sibilance. When using the chain for Arya, hd800s or Stax 007 mk2 I do not have any sibilance at all. The difference that I find vs the Master is that the Master has a bit, a bit laid back upper-mids and vocals are slightly calmer (pulled back). But when I introduce in the chain tube pre-amp presentation is easily changed in both directions via tube rolling or slight EQ
Jan 13, 2024 at 6:58 AM Post #567 of 1,443
Sibilant I made it a little worse than it reallys is, I actuall meant a little thin sounding (my mistake). And that is digital AND analogue. if you compare them, they have less stage, little colder sounding, less control. And with busy jazz tracks you hear noticable less control to keep the instruments apart. And a getting little messy with the seperation.
With the master that gets quite some better, more control, more musical, propably combination of different sounding opamps and femto clocks.
The A8 is on a whole other level, with that one the seperation of music, goes beyond the speakers. The a8 is digitial and analogue on a whole another level.
People can try to deny it, but the difference is quite noticble, but I listen on chord tt2 with mscaler, a musical fidelity m8xi and full martin logans esl, and on that set you won’t hide anything, good sounds bizar, and less is noticable.
On my headphone set with soloist 3 xrgt or my violectric 590 is is less noticable then on my full hifi set.
I use neither of them analogue, even the ak4493 dac in the hegel 590 sounded better than the a8 analague out.
I bought the a8 as a very good transport only. I loved the bigger brother 130 hifirose but I really hated the hifirose software, the eversolo app is spot on!! Easy, fast!
So I am not saying a6 is bad, it is amazing for the money!! Look af a hifirose 250, more than double the price!
Jan 13, 2024 at 1:22 PM Post #569 of 1,443
That's a bit more fair judgement and the level of chain matters.
Jan 13, 2024 at 4:26 PM Post #570 of 1,443
Just moved my Schiit Bifrost 2/64 back to my 2 channel setup. I'm running Roon w/ Tidal -> Eversolo DMP-A6 -> AudioQuest JitterBug FMJ -> AudioQuest Carbon USB -> Bifrost 2/64. I think the Bifrost 2/64 is a significant improvement over the internal DAC of the DMP-A6 in my system. YMMV.
