No, digitally a6 master is the same like a6, just the audio output citcle is slightly inproved. The a8 is already a level up in audio a nearly two levels up in digital (if you have rhe chain to explore it)I wish I had the oppurtunity to compare the A8 and a6 master at home digitally. I borrowed the a6 and a8 master, assuming they sound digital the same, which they don’t.
I actually hope that the master a6 and a8 sound digitally the same. Than a6 master is the better choice price wise as a streamer alone
Eversolo DMP-A6 Network Streamer/DAC
- Thread starter PopZeus
REXNFX
- Feb 18, 2014
Guess you didn't watch the video I posted.No, digitally a6 master is the same like a6, just the audio output citcle is slightly inproved. The a8 is already a level up in audio a nearly two levels up in digital (if you have rhe chain to explore it)
Check the internals and tech specs of digital outputs. You cannot turn silver to gold even you see they glare the same.
jjazzy
I did but that was a comparison between the a6’s not the a8 includedGuess you didn't watch the video I posted.
jjazzy
Yes I heared the difference between the a6 and a8 digital(usb), connected them to a tt2+mscaler, the a6 just sounded awfull, switching back from the a8. Not really ofcourse, it just showed how much better the a8 is, not only analogue but also digital.No, digitally a6 master is the same like a6, just the audio output citcle is slightly inproved. The a8 is already a level up in audio a nearly two levels up in digital (if you have rhe chain to explore it)
No difference in digital at all and very slight in analogue, since both DACs are measurably transparent
jjazzy
Difference between?No difference in digital at all and very slight in analogue, since both DACs are measurably transparent
Because between the a8 and a6 through usb digital made quite the difference, so much even my wife heared it (and she does not care about hifi at all)
So than tell me what makes this huge difference? (Because I conducted a blind test with my wife, from all 5 times, I picket out the A8 over the a6 (normal version) (digital connectes through usb at the tt2+mscaler.
The a8 sounded much fuller, less thin.
Do know I have a very revealing amp
And even more revealing speakers (full esl martin logan’s)
Obviously your blind test was not properly done
jjazzy
I can assure it was, same cabling, same dac, same tracks. If you occasionaly pick them out, I agree, but every times pickout the difference not. It was easily picked out because it sound thinner.Obviously your blind test was not properly done
Did not compare digital it with master edition, I wish I would have. But the a6 was less. So of it is not the clocks than it is the seperate power supplies
What makes you think that they should sound absolutely the same?Obviously your blind test was not properly done
REXNFX
- Feb 18, 2014
You're making yourself look a bit silly. Suggest you check the components in each unit and get back to me.Check the internals and tech specs of digital outputs. You cannot turn silver to gold even you see they glare the same.
REXNFX
- Feb 18, 2014
Suggest you ignore trolls like fofofool.I can assure it was, same cabling, same dac, same tracks. If you occasionaly pick them out, I agree, but every times pickout the difference not. It was easily picked out because it sound thinner.
Thanks God you used the same cables as they make a huge differenceI can assure it was, same cabling, same dac, same tracks. If you occasionaly pick them out, I agree, but every times pickout the difference not. It was easily picked out because it sound thinner.
jjazzy
God don’t be so annoying and stubborn.Thanks God you used the same cables as they make a huge difference
A6 users. Can you share your experiences playing local files? Is SSD installed in A6 or externally connected to the back side of A6 beneficial sound quality-wise compared to streamed from PC attached drive?
Total: 7 (members: 1, guests: 6)
