DJShadow
- May 8, 2005
Noise cancellation and sound isolation are two different methods used to achieve the same effect-blocking out ambient noise. Etymotics and Shures are sound isolating, whereas some Sony buds and Bose headphones (forgot which model) emit frequencies that are supposed to cancel out ambient sounds by matching their wavelength/frequency. From I've read, these solutions are inferior to the seal method used by Ety and Shure.
If you feel you aren't getting enough isolation then you haven't inserted them properly. What you can try is to pull your ear up (the pinnae) and outwards to 'straighten' the ear canal, then insert your er6i. That should provide better isolation as the earpiece rests further in your ear.
