homer_555uk
- May 13, 2006
just got myself some er6i's and am really happy with the comfort and isolation of the 3 flange tips, however id like them to go a little deeper into my ear, setting aside comfort and isolation which tips would allow the whole thing to sit deeper in my ear , ie changing the tips to 2 flange etys? or olives/complys or getting custom moulds?, at the moment the end of the piece sits pretty flush with the outside of my ear so only slightly visable from a side view, would any of the above suggestions make them sit that little bit deaper in my ear? any other advice would be great (just to clarify i want the iems to sit deeper in my ears , seen as you cant change the size of them i was thinking of changing the tips , 2 flage tips are shorter than 3 flange tips?, am i thinking the right thing?
