dukeReinhardt
- Apr 1, 2012
guys i'm not familiar with headphone power requirements and such but i'm going to be getting something like an essence stx soon (specifically looking at the creative zxr, which uses the same chip and presumably similar circuitry). i hear it actually has not a lot of power output (mW).
here's a quote regarding the headphone amp section:
"TPA6120A2 is able to swing only within +|-10 V with +|-12 V supply and 10 kOhm loading.
Measured output power with 33 Ohm loading is 650 mW.
Measured output power with 300 Ohm loading is 120 mW."
and here's another source that says it outputs ~200mW at 62ohms:
http://www.head-fi.org/t/476602/asus-xonar-stx-built-in-amp-and-k701-synergy
my headphones, the HD 280 pro, are supposed to have a max input wattage of 500mw and they're 64ohm. some headphone amps can output up to 1w, and the stx doesn't seem able to do that. does that make it a poor investment as an amp (i do intend to branch out from the not-so-great hd 280 at some point), or does it mean it might not be enough for the hd 280? basically what do these numbers mean, and could you give me an example (like a specific headphone) where the stx would be inferior to a 1w headphone amp?
regarding resistance, am i right in understanding that the resistance in ohms is only significant because the resistance of your headphones should be 8 times or more than the output resistance of the source?
thanks
thanks
