Batmaz
- Jun 26, 2015
The FiiO E10K ($76) and Schiit Fulla ($79) are both USB/DAC/amps
What about the Schiit Modi? They have some old stock left over for the same price as a Fulla.
I think you misunderstood me. I want an amp and a DAC, separate devices. I understand it will be a little more expensive, but they generally have better quality when they are individualized products. I believe it is possible to obtain an amp and dac for my price range...
I would say a Modi DAC for around the same price as the Fulla is a good value.
You mentioned the NFB-11 before, I believe. If I were to hook it up to my KRK's, would I use the DAC out with RCA to the speakers?
Yes. You would connect the RCA out on the back of the NFB-11 to your speakers.
The specs for the Topping TP D2 that I could find show it to be a very weak headphone amp compared to the NFB-11.
Yep, the NFB-11 comes with 2-channel RCA outputs, perfect for connecting to a pair of self-powered speakers.
