Essence STX ASIO help
Jan 8, 2014 at 2:55 PM Thread Starter Post #1 of 3
idkwho
Hi, I would like to set up foobar 2k with ASIO but I am unsure on how to set it up properly.
Do I just download the asio foobar component and select ASIO device? Or must I download ASIO4ALL too? I thought the Essence STX has native ASIO driver support? Is this true that I do not have to install ASIO4ALL?
Thank you for all your help.
Jan 8, 2014 at 3:19 PM Post #2 of 3
if you install the drivers for the stx, the native asio driver should install with it. There is an asio plugin that needs to be installed in foobar first ( find it in the component section on the foobar webpage) Then all you should have to do is change the audio output setting to asus asio in your media player
