mbrennwa
- Mar 14, 2014
I don't know, but I can speculate... I am pretty sure that both the MT and BHSE would reproduce a pure, low-frequency sine test signal in the same way. However, what you're listening to is not a sine signal, but, for example, a bass drum. The stick hitting the drum will create a signal with a very sharp rise, followed by a long, smooth "tail". The sharp rise requires the estat amplifier to pump a lot of charge into the headphone very quickly -- in other words, it needs to output a large current. If the amp struggles with this, it will distort the output, and the bass drum will not sound right.Great info - any other insight as to why the MT might have stronger low end than the BHSE given they typically have the same PSU
I did some tests on the voltages and currents needed to drive estat headphones here and here. The results were not unexpected, but they also showed that something like a Stax SRM700T is far from capable of delivering enough current without distorting the output badly. Both the MT and BHSE will be much better, but maybe one is slightly better than the other.
Do you have a link to these tests / data?For whatever reason, changes to the amp's feedback solution can produce audible changes that are very hard to measure in headphone FR.
A modification of the feedback would almost certainly change the profile of the harmonic distortion. For example, if you use a 1 kHz sine test signal, you would observe the harmonic distortion products at 2 kHz, 3 kHz, 4 kHz, etc. This test is very different from measuring the frequency response, where you'd measure the (linear!) voltage gain of the amplifier at different frequencies. Vice versa, the frequency response does not show the harmonics. It's therefore no surprise that the headphone frequency response did not show any effect related to the change of the feedback.
