Mr Iriver
- Oct 17, 2004
Between the ER4 ER6i, and E3, I prefered he E3. That is based on Rock/metal music. I find the ety's to be just so thin in the midrange and bass, that it is not very enjoyable to listen. Using an equalizer makes the bass louder, and so the midrange, but somehow their bass and midrange is always very thin regarless of loudness. The shures on the other hand have a full bodied bass, that takes EQ well.The Ety's however have a better high end, especially the ER4. The E3 on the other hand also sounds very clear (not as clear though close), though by comparison much fuller sounding in both bass and mids than the Ety's. Also the E3 mids I find to be the best midrange out of the 3. The bass also while not as tight as the Etys sounds closer to real bass. The highs are a shures problem however. The highs can be fixed with equalization. Once equalized, you get more detail, and a more balanced sound. If you can equalize all pairs I recommend the Shures. The will sound about as detailed as the 6is but with a fuller sound, and if you equalize them, even more detailed. ER4 detail is still unreachable by either, but E3 fullness also is unreachable by the other two. With an equalizer I would definately choose the shures (unless I look for detail meaning ER4), without one, it would depend on what you prefer, highs or bass.
