hwanmeister
- Oct 21, 2005
Hi, I'm a noob, although I've been ghosting on the site for quite some time
Anyway, I've got a dilemma that I need some advice on. I'm currently using Etymotic er6i on my Kenwood HD20GA7, but recently I've come to consider upgrading. I've had my eyes on either er-4p or e4c, but I can't really pick one.
Particular sounds (bass or trebles or what-have-you) are not that important. Just an overall view on which canalphone is generally preferable. Sorry if this sounds a bit unreasonable, since I'm sure both are great phones and the differences in quality are not that great. (Or perhaps the performance of er6i is not that inferior to the two 'phones..?)
I would really appreciate your help, thanks.
![biggrin.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/biggrin.gif)
