equivalent circuit model for headphones?
Dec 1, 2006 at 1:10 AM Thread Starter Post #1 of 3
DCameronMauch
Does anyone know what the equivalent circuit model for regular headphones would look like? If it makes any difference, I am considering the AKG K701s. They are 62 ohms. Also the cable. Want to check with circuit simulations to verify general loop stability. Thanks.
Dec 1, 2006 at 2:02 AM Post #2 of 3
http://www6.head-fi.org/forums/showthread.php?t=78369
still searching?
didn't find:
http://www4.head-fi.org/forums/showthread.php?t=170869
why not measure audio frequency with soundcard and current sense resistor
for cable you can measure C pretty easily, exact L depends on geometry and good inductance bridges aren't too common, but the math is easily found if you can measure the dimensions - wire dia, seperation
my 1st comment 2 yrs ago still stands - for amp stability Cload is the main player, and estimated cable C can easily be lumped at the amp output - the headphone coil Z is unlikely to matter as much at hopefully near MHz loop gain intercepts
Dec 1, 2006 at 4:29 PM Post #3 of 3
Thanks for the pointers. I remembered I had asked this question a while ago but didn't get any responses. The second link was very usefull. I am using roughly 10m cables. So I am guessing roughly 1.5nF lump capacitance.
