Exacoustatowner
- Feb 8, 2015
How about for someone with hearing loss? I am down 8-10 db from 1K all the way to 8K-(limit of test)-in an oddly flat manner-and I assume more rolled off in the higher frequencies. I have hearing aids to correct this in everyday speech-but they are NOT good for music-and are limited to 9Khz.
I bought an ART EQ 355 31 band Graphic EQ (designed for live performance use and PA). I am able to boost 1K, 1.25, 1.6, 2, ,5, 3.25, 4, 5, 6,8, 10,12.5, 16 Khz to roughly match my loss. Nice to hear cymbals clearly again! The audible distortion added is small but noticeable to my ears. The real problem is that the sound stage collapses to what I perceive as half. Listening to a trio-it's as if they all move close together on the stage. Even with all sliders set at flat.
My source is an OPPO BDP-105D.
On the STRONG recommendation of another HFer I ordered a higher end EQ. Rane DEQ60L and an unbalanced to balanced transformer (my AMP has no balanced inputs-although the Oppo BDP-105 D has balanced outputs. So I'll go XLR from Oppo to Rane DEQ60L-then to the converter to RCA unbalanced in.. My music sources are CD, SACD, BluRay Audio.
My listening tests are via HiFiman HE-560 headphones. A) was directly from the Oppo (well reviewed built in HP amp), B) from my Yamaha RV657 hp out C) Oppo-to ART 355 to Yamaha RV657 via RCA unbalanced.
Results- the EQ restores my hearing loss fairly well while adding a hint of "mud"-but seriously reducing the width and depth of the soundstage, Imagine a jazz trio performing on a small stage in an small venue as compared to putting them in a small bathroom! The Yamaha without the EQ did not obviously change the sound stage-although there sound quality took a tiny hit-only noticeable to me on repeated A/Bing of the same 10 seconds of music. I could live with it! But the tiny soundstage-not so much.
Without EQ the sound is still good-if quite SOFT. Cymbals, violins, female voices sound a bit too laid back.
