Beefy
- Mar 4, 2008
This question is primarily aimed at AMB, but is open to all comers...... I'm trying to do something a little different with an Epsilon 24, and am having some problems.
What I am trying to do is use an external relay to reverse the polarity of the voltage supplied to my Bulgin dual-colour switch; the plan is for the switch to change colour on SPDIF lock. The external relay is a spare Twisted Pear OTTO I had lying around.
On its own the external relay functions perfectly, and under normal conditions the E24 is working without issue. But as soon as the LED polarity is switched through the relay, the E24 powers down. I am guessing what happens is that as the relay starts closing/opening the LED goes open circuit, which de-stabilises the E24 and turns it off.
I can partially stabilise the E24 by running a 2.2kohm resistor in parallel to the LED, so that it never goes open circuit - this works for about 50% of switching events from the external relay, gives proof of concept, and suggests that everything is wired up incorrectly. But before I start randomly trying other stuff or different resistor values, some expert advice on keeping the E24 on and stable while the LED switches would be greatly appreciated.
Further info......
I am using this SSR which works great normally.
I am not using thermistors, and J2C is jumpered.
K1, Q1 and D2 are installed (I was originally going to use the E24's own relay for switching but decided against it), but R4 is not, thus keeping them out of the circuit.
I tried running 220ohm across the SSR's control terminal with no success.
Thanks for looking...... I look forward to your suggestions!
Further info......
