3X0
- Sep 2, 2006
I want to start recording.
The equipment I already have and will be using:
Shure Beta 58 (with XLR cable)
JHAudio JH13 Pro
So I'm thinking of getting an interface as well as a MIDI keyboard. As for software, my school provides subsidized copies of Pro Tools and Logic Pro, so no worries there.
The two options I was looking at for the interface include the E-MU 0404 USB and the Apogee Duet. My HTPC has an OS X partition (Hackintosh) and FireWire 400, so either should function optimally. Not sure about the keyboard, though. I was looking at M-Audio's Axiom series, probably a 49 or Pro 49. Not sure which one is the better value.
I have a budget of about $600 for the keyboard and interface, but obviously the lower the better. I intend to buy second-hand. If it sounds to you like I don't know what I'm doing, you'd be correct: I'm just going to start playing around for a couple of weeks and see what happens. With that in mind, what's some sweet stuff to learn on?
JHAudio JH13 Pro
