oogabooga
- Dec 2, 2008
So I'm considering getting a DAC to connect between my Macbook Pro and my XM5 and I want to use the Macbook's optical out, as I've had a number of USB problems recently and I've read that the optical line might be a little cleaner. I have two major criteria - price (hopefully under $200) and ability to buy in Canada (I HATE dealing with Customs).
I'm considering the following:
Super Pro 707 ~$130
E-MU 0404 ~$230
Beresford TC-7510 ~$100+ used?
Spitfire ~$270
HR Micro DAC (hopefully used from Canada) ~$350+ used?
A Zero, if anyone knows where to buy one in Canada.
Does anyone have some thoughts to share on these DACs, and if any are particularly good/bad? Any other optical-in DACs that I've missed? Would I be better off using line out to the XM5, or the built-in headphone amp in the case of the E-MU/Zero? Is the ability to listen at 24/96 or upsampling to 24/192 really that important cf 16/44.1 for most FLAC/MP3s?
Thanks!
Super Pro 707 ~$130
E-MU 0404 ~$230
Spitfire ~$270
Thanks!
