pteixeira
- Aug 26, 2013
Hi there!
I have been using earbuds since forever (Sennheiser MX 260), but I think I might get better sound via IEMs.
I am looking for some entry-level IEMs. I am very "weird" about IEMs since I get very uncomfortable with the vacuum some of the IEMs I tried created, so I am looking for something that I will not regret buying and then not giving it much use.
Some folks at another thread suggested I used Comply foam-tips, so they need to be able to use them (not sure if this is a universal thing).
As the title says, I mostly listen to Rock and EDM, some Chillout.
Source would be an iPod touch 3rd gen.
Also I live in Europe, so that must be a factor regarding the IEM manufactor. If it can be purchased via amazon.co.uk even better!
Thanks in advance, any questions you have I will be more than happy to answer
