Cronnix
- Sep 28, 2013
Hi all. I'm out for budget headphones that I'd use mainly for music with occasional gaming. I've been browsing various reviews and guides and ended up with those four models:
I am curious if you can suggest which one would suit me best based on my preferences, as well as possibly suggest cheaper alternatives to 8400/M50 (I'm after full/half-sized, closed). I also have a question if 8400 requires an amp for good sound, and if Behringer - MA400 Micromon would be enough (basically only one I can afford, will it even make a difference?). The budget is max $200, and as I live in Sweden all the electronics are bit more expensive here. The phones will be plugged straight into the PC motherboard or in the above-mentioned amp, alternatively into cellphone. I mostly listen to gaming music, epic trailer music (like two steps from hell), rock, metal, folk, bit of techno and lately some "relaxing" and calm music. I appreciate decent bass but nothing over the top. Would be a great bonus if they had a mic but not a deal breaker.
Thanks!
- Audio Technica ATH-M50
- KRK KNS-8400
- Sennheiser HD449
- Sony MDR-7506
Thanks!
