bigshot
My reply appears to have vanished with the outage... I'll try to reconstruct it.
The main differences between an advanced P&S and a low end DSLR are:
The DSLR will have a stop and a half to two stop advantage in low light because of better high ISO noise performance. But the lens on the P&S, like the Panasonic Lumix FZ-18 has an effective (35mm equivalent) focal length of 24mm to 500mm. You'd need at least three lenses to do that with a DSLR.
The biggest difference is cost though. For a usable D40 kit (18-55, 55-200) it will set you back $600. The Lumix is a little over $350. To get close to the $400 mark with the D40, you'd have to settle for just the 18-55. You can be guaranteed that you'll probably want another lens in the not too distant future.
The Lumix has all the same exposure, focus, white balance and ISO controls that the D40 does. There is no real difference in build quality. The main difference is the cost and the fact that the DSLR requires a kit of lenses, while the Lumix has one lens that does it all.
See ya
Steve
Originally Posted by dima1109 /img/forum/go_quote.gif Steve, what would be the principal difference between an SLR-like camera and a true SLR? (I don't care about video, that's the main difference I can think of) |
See ya
Steve
