Sorry to revive an older thread, but I didn't feel the need to start a new one.
I had access to a Bell Model 4180 Extremely Low Frequency (ELF) Gaussmeter FW Bell 4180 ELF Meter and I love doing experiments, so I decided to test the electromagnetic fields (EMF) from a pair of Beyerdynamic DT 770 and Sennheiser HD201. I will tell you my results first, and then I will give you my take on things based on the limited research I have done.
I measured the sound pressure level using a Radioshack Digital meter, and then I placed the Gauss meter where your ear would sit. I zeroed the Guass meter to the ambient fields in my room, so the measured field (in milliGauss) is the excess produced by the headphones. I measured both the left and right earpiece, and as expected, got pretty much the same results. The field varied with the instantaneous sound level of the track I used. The values shown below are an average over a portion of the track.
Beyerdynamic DT 770
65 dB - appriximately 0 mG
80 dB - ~1 mG
90 dB - 0.5 mG (1.5 mG if you push hard into the ear pads)
Sennheiser HD201
80 dB - ~1 mG
90 dB - 2-3 mG
Since I listen to my music around 65 dB, I am have nothing to worry about. But, here is my take on the issue based on a little reading I did on the Internet about this topic just to be sure my house was as safe as possible for my soon-to-be-born son. I have a scientific background, and I can usually smell bs and new-age pseudoscience pretty easily. But I am still not convinced either way.
My research focused on low frequency magnetic fields, primarily on the internet, and unfortunately, I didn't do my full diligence and dig into the studies cited by the sources I read. But, here is what I found.
I was surprised to find that the standard rebuttal, which I had always believed, that non-ionizing radiation cannot cause a biological effect except due to heating is not true. There have been many studies demonstrating biological effects (e.g., changes to cell membrane permeability) due to such fields. However, the effects at the cellular and organism levels are still not fully understood, nor have scientists established a definitive safe threshold. Most of the limited studies and sources will somewhat arbitrarily suggest safe values in the 1-3 mG (milliGauss) range. The average ambient level (i.e., away from appliances and electronics) of homes measured in several studies is in the 1 mG range. Therefore, you might surmise that long-term exposure (e.g., in locations of sleep) to higher levels of magnetic fields is abnormal. Apparently, it is the alternating magnetic field hat has the strongest biological effects (low-frequency electric fields and DC magnetic fields don't do too much apparently). Basically, my take on it is that strong low frequency magnetic fields may or may not have health effects. However, if there are simple remedies to lower your or your children's exposure (e.g., moving radiating appliances from where you spend most of your time), then why not.
