frix
- May 7, 2012
Is the diva vented?
I had to return Diva for fit issues
Also thinking on selling the Diva , it’s big but for me the nozzle is the problem.. to get a good seal I need 13mm 13.3mm eartip size and with big nozzle it hurts. Can’t use the diva for more than a hour…Huge size or insertion? I would love to try this model but fit seems reserved to some people only. Thanks.
Hello, the upper portion of the shell put pressure on my ears. Couldn’t wear them longer than 15 or 20 minutes. Tried many tips to see if I could position the IEM for less discomfort in that area but didn’t have success. I use large tips and my Mason 2 is very chunky so I didn’t ever anticipate fit as an issue. I’ve had Spartacus for about a month and thankfully discomfort isn’t an issue. Wonderful IEM as well. I perhaps could have gone the custom route but it didn’t occur to me until after I returned Diva. Hope this feedback was helpful.Huge size or insertion? I would love to try this model but fit seems reserved to some people only. Thanks.
Yes. It's does not feel as sealed in as a closed BA set like Andromeda, but it does not feel pressure-free like a vented DD (or something like 64 Audio IEMs) either.Is the diva vented?
I had less problem problem with MEST III, but I wouldn't consider either to be "super comfortable." The MEST III fit my ears better, as if it is custom, but it also has pressure build up and driver flex. The DIVA has too large nozzle that tends to lose seal after a while, unless I use a pair of sticky ear tips.Had a good laugh visualizing someone inserting an in-ear 'potato'
How do you compare Mest MK3 to Diva? I though they were comparable in size.
Pov: Send a picture of your ears next to a banana for referenceI have been demoing Diva for a couple weeks now, and while it's large, it's not bigger than its big brother, Annihilator! Despite their sizes, I find both very comfortable for hours on end. YMMV and all that.
Not ripe, but my ears aren't too huge!Pov: Send a picture of your ears next to a banana for reference
I'm on the medium side, EXT nozzle was the limit with 40mins max audition.
