I've used dozens of 807s in the 8200 over the years, including ceramic ATS-25s, without issue. I have also blown two FETs thus far, knock on wood! On the DX version, the light always turned purple I believe when the FETs blew (it's been awhile). Both times the tubes were bad, with one blowing while running in the amp! The newer R version has protections built-in, so this may be where the orange light and sound stopping, without blowing a FET comes in.
@aedaza, do you happen to have the 8200R?
Initially I was unaware of the 807 type working in the 8200, but I found a few meet/show pictures of Victor's early on where he was running them and he told me they were okay to use in the amp. I've enjoyed them quite a bit since, especially the ATS-25s, but often find them lacking the finesse of certain other NOS types, however those at much higher prices. They do however usually sound much better than many others I have, often having a nice in-between sound.
One issue I ran into is that US 807s tend to have a bigger top pin than their European counterparts. I actually have 3 sets of adapters now; some fit the US snugly, but are loose on the Europeans (I only use them if they are snug), and others that fit the Europeans snugly, but won't even begin to fit over the tip of the top pin on the US ones. I'd have to count, but I think I have around 70 or so 807s at this point, all sorts of manufactures/variants, smoked, ceramic, hand-painted, etc.
I'm no expert, but Victor should be able to address any concerns regarding the 807s and/or technical questions of their use in the amp, R and pre-R, through Mr. Fujita.
I hope this helps! Keep on rocking those 8200s!
