UntilThen
- Jun 16, 2015
I'm still blown away by the Elekit TU-8200 driving my He1000se. There's a holographic ring to music. Will be back later with the Gold Lion KT77.
I built the TU-8200 last week with the 6L6GC + 12AU7 tubes, upgraded resistors + capacitors. I had the enclosure powder coated matte black. This was a first time build for me (and first single driver tube amp) and it took me the better part of a weekend. I could not be happier! Victor immediately answered a number of my questions while putting it together (all of which was very satisfying) and I absolutely love the sound! I'm currently running in Ultra Linear mode, listening through HiFi Man HE-400i and Audio Nirvana Super 8 Alnico full range drivers in custom built mini monitor cabinets. I have a Audio-GD NFB-28 Preamp/DAC/Balanced Headphone Amp but I much prefer the headphone section of the TU-8200. I look forward to trying different tubes at some point.
With the help of the automatic bias adjustment feature, you can roll quite a few popular audiophile vacuum tubes in this amp, including the following:
- Power Tubes:
- 6L6GC, KT88, 6550C, 6CA7, EL34, 5881, KT66, 807 (with adapter), KT77, KT99 as well as all of the usual direct equivalents of the 6L6GC. However, 6L6's and its variants are not recommended, only the GC.
- Input/Signal Tubes:
- 12AU7, ECC82, CV4003, 13D5 as well as the usual direct equivalents/replacements of the all of these types
great info. Thank youI agree, these tubes are in short supply and prices will continue to rise. The nice thing about the 8200 is that while you still have choices for NOS, if you are willing to pay, there are also options for new stock, which are getting better every day.
The best way to determine if an EL34 is a true Mullard, as well as additional info, is from the etched code on the tubes, usually to the side or behind the printed label on the tube. These etchings do not usually ware-off, so even if the label is gone, you can still usually tell.
There are many resources available online about these codes, including the one below:
https://mullard.org/blogs/news/mullard-valve-etched-codes-how-to-interpret-them
Mullards will also typically have a single or double halo getter at the top and welded plates. Below are a few pictures of both the halos as well as the codes:
Over the years I've been able to get really good prices on rebranded Mullards by knowing what to look for. Many believe the ones made at the Blackburn factory are the best, with slight differences between XF1s, XF2s, XF3s, etc.
Let those puppies break-in and enjoy. The Gold lion 12au7's are very good too.
Two questions for @UntilThen: When listening to headphones via the TU-8200, do speakers have to be connected as well? What are the lowest and highest impedance headphones that you have successfully used with the TU-8200?
Well, you have a new amp-owner-in-law (...?). I just purchased a TU-8200R from a EE builder/seller on eBay. The 8200 has upgraded Mundorf aluminium capacitors, ALPS 27, and more . I have my order in for Genalex/Gold Lion EL34s (cryogenically treated) and am stocked with Brimar 12au7s & Raytheon 7730s. Itching to run the gamut from Gjallarhorn JM to ZMF Auteur...from Focal Clear to Senn HD600.As much as I love the Wa22 and LF339i, I find myself using the Elekit TU-8200 almost exclusively today. The sonic signature of the amp is burning into my brain even as I let the KT77 burn in for 6 hours now. TU-8200 is the cheapest of my amps as I bought it used but the tone is just great.
Starting to get a glimpse of the KT77 tone. In fact on first listen, it's already great. It seems to be half way between KT88 and 6L6gc tone. KT88 is bright and 6L6gc is warm and KT77 is somewhere in the middle but more towards 6L6gc end. So the bass is great but tight and the mid is lovely and organic. The highs is pretty sparkly. Physically it doesn't look too great. Kind of skinny and very slim, like a model.
This could be my fav power tubes of the 3 but I'll let it burn in to the 100 hours mark. That will take 3 weeks. by which time more tubes would have arrived.
A pic...
